Opel Grandland x 2.0 cdti 177 year 2019.
The car is purchased without DAB radio.
Questions? Can it be installed afterwards?
DAB radio
it should be possible, but it cost a little more
Thanks Freaky, do you have any idea what spare parts to use for this change?
Maybe this one:
http://www.opel-freisprechanla…ruestset-grandland-x.htmlI dont have any experience with it. Just came up on google results. Translated description below.
Zitat von DAB+ PaP-ShopWith this you can retrofit in your Grandland X digital radio reception (DAB +).
Operation is via the existing display of the navigation system / radio, as well as via the steering wheel buttons. Depending on the model, the supplied antenna is installed in one of the rear side windows or the rear window. When installed, the antenna is virtually invisible.
The scope of supply includes the control unit, the antenna as well as the cable and plug to connect the control unit to the vehicle.
